★ Experience case of handling the problem that switch packet filtering does not take effect on traffic accessing the local address
2023-12-27 20:03:59 Published
  • 0 Followed
  • 0Collected ,8513Browsed
Network Topology
PC (10.1.12.48)----SW (10.1.58.1)-----Internal host (10.1.58.151)
Problem Description
The packet filtering configuration is delivered to the interface. The deny rule in the rule is as follows. The test can successfully deny the matching passing packets. However, the test packets sent to the CPU cannot be denied and can pass.
Advanced IPv4 ACL named deny_ssid_dev, 2 rules,
ACL's step is 5, start ID is 0
 rule 9 permit ip source 10.1.46.150 0
 rule 10 deny ip destination 10.0.0.0 0.255.255.255
interface Vsi-interface3
  description SDN_VSI_Interface_3
  ip binding vpn-instance SQLS-WJ
  ip address 10.1.12.1 255.255.255.0
  mac-address 0000-0000-0001
  local-proxy-arp enable
  packet-filter name deny_ssid_dev inbound
Specific business flow:
10.1.12.48——10.1.58.1 (SW local) is accessible
10.1.12.48——10.1.58.1——10.1.58.151 (passing) is blocked
Process Analysis
1. Collect all ACL delivery status of the corresponding board bottom layer in the probe view.
debug qacl show cha 1 slot 0 chip 0 verbose 20
debug qacl show cha 1 slot 0 chip 0 verbose 40
debug qacl show cha 1 slot 0 chip 0 verbose 60
…………. (every 20 steps, collected until no content is displayed)
2. It is found that the ACL system priority of the ICMP delivered by the system and sent to the CPU is greater than the packet filtering deny. Therefore, the ping packets from the device are directly sent to the CPU for processing and cannot be filtered out.
Acl-Type PktFilter IP on L3 VSI, Stage IFP, Pipe 0, OuterPort, Installed, Active
Prio Mjr/Sub 523/503185397, Group 5 [5], Slice/Idx 5/2, Entry 5015, IntraDb: 3842/4610---------- The larger the Prio Mjr value, the higher the priority.
ACL GroupNo : 637534210, RuleID : 10
Rule Match --------
        Lookup: STP forwarding, L2 dst L3 bit[y], 0x118, 0x118
        Dest IP: 10.0.0.0, 255.0.0.0
        IP Type: Any IPv4 packet
        L3IIF: 0x100f L3IIFMask: 0xffffffff
        NO_HG
Actions --------
        Deny
Acl-Type RX IPv4 Middle, Stage IFP, Pipe 0, Global, Installed, Active
Prio Mjr/Sub 527/24, Group 1 [1], Slice/Idx 0/147, Entry 3514, Triple: 147/915/1683
Rule Match --------
        Ports: 0x01fffffe0007ffffe; 0x21ffffffe1fffffff
        Lookup: VLAN ID valid[y], STP forwarding, 0x1c, 0x1c
        IP protocol: icmp
        Dest Port: CPU
        DropBit: 0x0, Mask : 0x1
        SysmRule Index : 44
        L3 Dest Class id: 0x3, 0x3ff
        My Station Hit
Actions --------
        CAR cir 0x200, cbs 0x800, pir 0x200, pbs 0x800, mode srTCM color blind,Bytes
        Account mode  packets,  green and non-green
        Redirect and copy to cpu
        Change CPU pkt COS 22
        Permit
        Red Deny
        Red_Copy_to_cpu : No
        Yel Deny
        Yel_Copy_to_cpu : No
MatchedName:44, ICMP
Generally speaking, the priority of the rules sent to the CPU in the inbound direction is higher than the user-configured packet filtering, PBR, and MQC rules, causing the user-configured deny filtering rules to fail to take effect.
Solution
Configure local PBR to discard packets processed by CPU, rules in ACL need to match specific details to prevent impact on normal packets. Testing with the following script can filter successfully, and the terminal cannot ping the device.
Specifying a policy for local PBR
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
For example:
interface Vlan-interface50
ip address 50.0.0.1 255.255.0.0
acl number 3999
rule 0 permit icmp source 50.0.0.1 0 destination 50.0.0.5 0
policy-based-route cc permit node 10
if-match acl 3999
apply output-interface NULL0
ip local policy-based-route cc
Please rate this case:
0 Comments
No Comments
Add Comments:
